Need ROM Samsung 1TB F3 Family | HE103SJ FW: 1AJ30001
GuideRecovery
Postby GuideRecovery » 29.01.19, 16:37
Anyone has this ROM ?
Drive is Samsung 1TB
Model: HE103SJ (DELL OEM)
The symptoms are that drive refuse to spinup with original pcb+rom, have tried to swap rom to donor pcb but same. drive only spin up with donor pcb + donor rom. So i guess rom is faulty.
Information about dump
Dump size............................... : 524288 bytes
Firmware checksum....................... : Ok
FIPS offset............................. : 0x0007F000
FIPS size............................... : 1024 bytes
FIPS checksum........................... : Ok
Firmware type........................... : Main Code
Original name........................... : 1AJ63uhM.126
Platform Id............................. : 0x1A
Head map................................ : 0, 1, 2, 3
thanks for checking.
Wasim Zafar
https://mindmergepk.com
Re: Need ROM Samsung 1TB F3 Family | HE103SJ FW: 1AJ30001
Postby digitalsupport » 29.01.19, 18:57
GuideRecovery wrote:Source of the post So i guess rom is faulty.
Check terminal output for any hints.
Maxim_TS
Postby Maxim_TS » 28.02.19, 13:39
GuideRecovery, try to hot-swap using a compatible donor drive, here you may see the steps: http://blog.acelab.eu.com/pc-3000-h ... ccess.html
If the issue is in ROM, you may use the donor ROM after overlays adaptation.
Return to “Spin Point”
