Rosewood ST1000LM035-Sysfile Write Eror
masterdisk
Re: Rosewood ST1000LM035-Sysfile Write Eror
Postby masterdisk » 19.08.18, 13:10
I was able to solve this problem. I backed up the modules. I did the translator regenerator via terminal. I recorded sys 28 back and solved the problem.
Paradog84
Postby Paradog84 » 18.09.18, 18:35
Can you message me with details please?
Masterclass
Postby Masterclass » 19.09.18, 06:01
masterdisk wrote:Source of the post I did the translator regenerator via terminal. I recorded sys 28 back and solved the problem.
An example of how to make everything INCORRECTLY.
Masterclass
Postby Masterclass » 19.09.18, 06:08
People, how about differentiating between MediaCache and MC Table? MC is a part of user area (huge in size --approx 60-80GB of most recent data). MCTable is like a huge Grown defect list (for better understanding). When you execute translator regeneration - HDD ERASES MC area and clears Table. Yes, after that procedure UA is usually accessible. But what will you say to your customer when 90% of MFT records were located in MediaCache and you personally killed it...
Nick_TS
Postby Nick_TS » 26.09.18, 15:13
Masterclass wrote:Source of the post People, how about differentiating between MediaCache and MC Table? MC is a part of user area (huge in size --approx 60-80GB of most recent data). MCTable is like a huge Grown defect list (for better understanding). When you execute translator regeneration - HDD ERASES MC area and clears Table. Yes, after that procedure UA is usually accessible. But what will you say to your customer when 90% of MFT records were located in MediaCache and you personally killed it...
Indeed!!!
The common issue on Rosewood family deals with MC Table (MCMT) but users usually reset the whole MC (not MC table only).
rms620
Postby rms620 » 24.11.18, 13:59
AYNIADAM wrote:Source of the post friends did not write here because in some cases the solution does not work. are largely solved by two separate methods.
Since this method is dangerous, it may be wrong to share it explicitly. I write with private message to the entrants.
I would like to know....Thanks
Abdurrahim.sopon
Postby Abdurrahim.sopon » 21.01.21, 10:47
AYNIADAM wrote:Problem is solved. There was a different solution for MCMT failure.
inbox please
Abdur rahim sopon
Dhaka-1205 Bangladesh
mobile:01912-881685
skype:rahim3720
mail:Rahim@datarecoverybd.com
www.datarecoverybd.com
AYESHA KHAN
Postby AYESHA KHAN » 12.02.21, 22:36
I would like to know please share me
Thank you
