Difference between DCM in 3.5 WD
Re: Difference between DCM in 3.5 WD
Postby DataMedics » 13.12.17, 18:43
The date is pretty far off, but this might work: https://www.ebay.com/itm/Western-Digita ... SwUlxaLdXv
osity
Postby osity » 13.12.17, 20:35
Good info. Thanks.
I eventually found an affordable drive (2000 years later) for under $100 and solved my case.
Postby AJ2008 » 14.12.17, 11:00
DataMedics wrote:And, while I've never yet tried it, I suspect that Diablo 3S family may be cross-compatible. The ariel density is slightly different, but close enough they might use the same heads.
These are interchangeable
Postby DataMedics » 14.12.17, 14:25
Thanks for confirming that. I'd always assumed it, but never yet tried it. I've been keeping a list of cross-compatible families here: https://www.data-medics.com/forum/cross ... html#p6487
I'll add that pairing to the list.
