Seagate ST2000DM001 Busy
Re: Seagate ST2000DM001 Busy
Postby Amarbir[CDR-Labs] » 23.01.17, 17:03
msurgeon wrote:Source of the post SIM Error 1002 indicates head problems. You will need to change heads on this to progress further.
Hi ,
I have solved this error by disabling defective head in Ram .I tried this in Freeplay family
msurgeon
Postby msurgeon » 23.01.17, 17:36
Blog procedure only works when bad head is a non-system head. You will need to do ROM edit of headmap, as Amarbir suggests, to see if one of the two system heads is good. If not then head swap is called for.
osity
Postby osity » 29.04.17, 22:19
Amarbir[CDR-Labs] wrote:Source of the post Hi ,
And did you swap the defective head afterwards to get the remaining data from that area?
Postby Amarbir[CDR-Labs] » 01.05.17, 13:33
osity wrote:Source of the post
No,
i did not client did not need that to happen
osity
Postby osity » 01.05.17, 18:45
Ah, you got lucky the data you needed was on that accessible platter.
Congrats.
