help finding Adapter/reading out NAND memory from Samsung S6 KLUBG4G1BD-E0B1
Typical Flash recovery cases
Multi-COM
Re: help finding Adapter/reading out NAND memory from Samsung S6 KLUBG4G1BD-E0B1
Postby Multi-COM » 10.07.17, 20:43
S6, S6 Edge, S7, S7 Edge and some new Xiaomi - all of them uses UFS (in this particular case it will be BGA 095) - not eMMC... only NuProg or FlashMax III support those chips
Boguslaw Rzepka
http://multi-com.eu
giroot
Postby giroot » 02.08.17, 21:27
Got a Samsung S6 Edge and removed the memory chip. However, the chip had a different layout underneath than OP.
The layout matches the BGA095 Dediprog adapters
There was another chip underneath the NAND flash.
Markings:
SAMSUNG
SHANNON333
A1528
537KW08
Markings were hard to read, so they may be off by a bit.
Anyone know what this chip is?
A quick google search says it's a modem/baseband chip?
antonvn
Postby antonvn » 04.08.17, 08:34
My advise is to get the datasheet for the chip to get the information that you are looking for. Go to http://www.alldatasheet.com/ and search for the chip, you will get pin-out information and much more. They will give you details about the package and once you know that, then you can search for an adapter.
Following is the information that I have for all Smart phones and I was promised that it is up to date:
1. eMMC30 11.5 X 13_0.5
2. eMMC30 12 X 16 _0.5
3. eMMC30 12 X 18 _0.5
4. eMMC30 14 X 18_0.5
5. eMMC30 11 X 10 _0.5
1. eMCP 11.5 X 13_0.5
2. eMCP 12 X 16_0.5
3. eMCP Test Socket_11.5 X 13_0.5
4. eMCP Test Socket_15 X 15_0.5
Maybe Roman can give us more information. I do not know the eMCP chips, it may be a new range or even an old range. I can see that we are going to need a lot of help with the cell phones and tablets.
Postby Roman_TS » 04.08.17, 09:15
PC-3000 Flash is not a tool for mobile recovery, so it's not optimize for eMMC and eMCP. But PC-3000 Mobile will :)
jerema
Postby jerema » 06.08.17, 11:50
Hello Roman,
and when the pc3000 mobile will be available ?
Multi-COM
Postby Multi-COM » 06.08.17, 21:52
@- SHANNON333 is IC which got two dies inside- LTE Modem and DRAM..... it has nothing to do with DATA that you are looking for - answer for your question I give already in post up but I think you not see it
@antonvn: once again... this is NOT eMMC or eMCP chip - and pinout will not help you either in those
Boguslaw Rzepka
http://multi-com.eu
Postby Roman_TS » 07.08.17, 09:43
jerema wrote:Source of the post Hello Roman,
We are going to release it closer to the end of 2017.
antonvn
Postby antonvn » 07.08.17, 14:17
Boguslaw,
Thanks for pointing it out to us..
antonvn
Postby antonvn » 18.08.17, 10:42
Gents, yes, I also need an answer to this. I cannot afford to buy this programmer and I am sure that many of my fellow Flash owners feel the same.
What can ACELab do for us, this is just another flash chip and I was told that the Flash system will be updated to cater for future chips, that is one of the reasons why I bought the Flash. The UFS chips have been available since 2011, according to Wikipedia. Different packages, I am sure.
Has anyone tried to find adapters for these new range of chips, will we be able to read it like Roman suggests - like the eMMC chips? I do not really want to invest in another programmer, I have about 5 and Windows do not support most of them anymore. I just want to get the data off the chip, I do not want to write to chips. This is turning out to be a bottomless money pit.
Multi-COM
Postby Multi-COM » 19.09.17, 17:29
@jerema: for this moment NO (or maybe by finding NAND pinout) - but there are other programmer for UFS which even support THGLF2G8J4LBATD not supported by DediProg... unfortunately cost 4400 USD for programmer + 2300 USD for 095 adapter.... cost 6700 USD. If you will compare to 1000 USD for DediProg you will see that it's cheapest methode available
Boguslaw Rzepka
http://multi-com.eu
studiogsm
Postby studiogsm » 14.07.18, 10:17
what Do you mean with complex soldering ?
I think I have to desolder the Chip and read it with an reader.
My question was : exist an other possibility to read this chip, without the dediprog reader for over 1000 US$ ?
I mean anything like emmc to SD or usb .
No. :)
jerema
Postby jerema » 10.08.18, 10:33
Just for information. See it on Alibaba:
https://de.aliexpress.com/store/product ... 66c4HC6kqU
radovanhlavacek
Postby radovanhlavacek » 12.03.20, 19:10
Hello, please help me. I can not find BGA95 PINout of THGLF2G8J4LBATD chip. I do not have adapter for it. I would like to read the chip without special adapter. I would like to use ACELAB SPIDER board for it. I want try to use UFED PHYSICAL ANALYZER for decrypt data from dump of the chip.
