Seagate ST9500325AS FW -D005DEM1 issue
Re: Seagate ST9500325AS FW -D005DEM1 issue
Postby Amarbir[CDR-Labs] » 05.04.16, 14:31
Dmitriy_TS wrote:Source of the post Hello Athena,
Athena wrote:Source of the post I can read system file 35 , I think this issue revolves around this file. I tried to copy it from other disk of same family but after that symptoms become worse & I was forced to restore earlier backup.
What to do now ?
Non-resident G-list is located in 26 system file on Wyatt family. But I'm not sure that problem is related to defect in NRGL.
Does drive still work slowly after cleaning SMART and unchecking background processes?
Dimitry Sir ,
Why Should it Work The Way Athena Is Trying to Make it Work ,As Far As i Know He Cannot Take a Donor 35 sys File .According To Me a Simple SMP Flags Setting Tweak With Selective Head Cloning Might Be Able To Fix This case ,Messing With Translator is Not Required If a User Can Read The First LBA and Last I Mean That Makes No Sense
Athena
Postby Athena » 13.04.16, 18:54
Hi Dmitry % Amarbir
Thanks a lot for keeping this thread alive.
Though Solution is not in sight . Disk is still going very slow. I cant access system files as I am getting Invalid buffer from file error (while accessing SMP flags for clearing)
What this error indicates and how should I tackle it ?
Athena
Postby Athena » 14.04.16, 14:51
Hi Dmitry
Yes disk is still slow , but customers patience is ending too fast.
I checked file 8F I have cleared SMP flags and saved file ,but that has not improves situation.
