840 Evo support
Bruno
Re: 840 Evo support
Postby Bruno » 15.05.17, 09:27
Hi Roman,
i have here a 840EVO, but after more then 30 tries with tweezers, the ssd will not come into safe mode.
Re: 840 Evo support
Postby Roman_TS » 15.05.17, 12:02
Hello. Try to solder both pins together with wire. Then - try again, SAFE should works fine.
Bruno
Re: 840 Evo support
Postby Bruno » 15.05.17, 14:09
Thank you Roman for the tip. Unfortunately don't work..
I have booth Pins soldering by wire, and trying:
See Log.
Selected family......................... : Samsung 840 EVO series
Controller.............................. : S4LN045X01-8030
Techno mode key......................... : Techno mode error; unexpected error: Device error detected - Device error detected - Device error detected - Device error detected
SSD status:
Loader uploaded......................... : No
Loader uploading
Code name............................... : 840EVO.ldr
Power Off
Power On
Safe mode............................... : Error
try again:
Power Off
Power On
try again:
Power Off
Power On
Operation aborted
Loader is not uploaded! Some of the functions are not available!
After Utility start, and i Switchen on Power, all LED are grey
After switch on with savepoints connected DRD and DSC are green.
May be, this SSD has forgotten his FW??
Re: 840 Evo support
Postby Roman_TS » 16.05.17, 09:00
Well, do you remember that for uploading LDR you should connect terminal to SSD? Did you made it?
Actually, situation is very strange. I can see that drive is not in SAFE MODE.
What about passport ID? Does it show ROM MODE?
Bruno
Re: 840 Evo support
Postby Bruno » 16.05.17, 14:53
Hi Roman,
shure i connect terminal to SSD.
But the problem is no switching SAVE mode.
The Utility showing nothing, no Model, no Serial, no Firmware, Capacity (0)...
see att. file.
Where i find Passport ID and ROM MODE?
SSD.rtf
(2.09 MiB) Downloaded 678 times
Re: 840 Evo support
Postby Roman_TS » 16.05.17, 17:24
Looks like final ROM corruption :) Not sure that we can do something with it.
Bruno
Re: 840 Evo support
Postby Bruno » 17.05.17, 08:38
Thank you Roman, :)
that is what i mean, with forgot the Firmware. :)
O.K. i Close the case, without recovering the data.
Have a nice day
Bruno
Return to “840 EVO Series”
