W.D Passport
Re: W.D Passport
Hello I have USB PCB 2060-800069-001 can I transfer chip to SATA PCB and what model I can use?
Re: W.D Passport
Any advice
Re: W.D Passport
At this point it would be easier to solder a SATA connector to the board and stop hunting for the compatible PCB.
Re: W.D Passport
paweliusz wrote:Source of the post Any advice
If I had to guess, I'd suspect it's a 2060-800052-000 board you want, since it looks identical to the newer wd10spzx SATA drives...but I've never tried it and I could be wrong.
Re: W.D Passport
Thanks guys !
Because of this thread, today for the first time I put Heads from donnor WD5000BPVT-22HXZT1 to Patient WD5000BMVW-11AMCS2 (both zephir) and it worked like a charm !
