How to make a com-port connection with WD USB drive
datasolution
Re: How to make a com-port connection with WD USB drive
Postby datasolution » 15.10.14, 19:52
pclab wrote:Hi AJ
But how to use it?
Is there anything on the manual about this? Where can I find more info?
Because I have a USB drive to work with, and if I could get this to work without the need of a PCB, ROM swap, etc, it would be great.
can u pls help me too.
my skype-id is datasolution1998
pclab
Postby pclab » 17.10.14, 17:38
The option appears now very cleary on the new version.
You connect the USB drive, then select USB family and it will start the utility.
petkus
Postby petkus » 06.01.15, 11:36
Is it possible to make com-port connection to 2060-771962 and 2060-771859 type pcb?
Are there Rx and Tx pins? I haven't had time to test the pins yet... :oops:
Thanks for any info.
Regards,
Peter
techrescue102
Postby techrescue102 » 07.01.15, 17:48
Also also looking for some info on a WD5000LMVW-11CKRS0 with a 2060-771859-000 board
Terminal outputs or SATA board would be great.
hddr49
Postby hddr49 » 14.01.15, 16:45
petkus wrote:Hi,
Regards,
Peter
On a 2060-771962, I use connections like usb2 drives
it has 6 pins in one row, like usb2 drives on fist picture on this thread. You can't use toshiba adapter because of case, but Rx, Tx and GND are the same (I use cdrom cable)
Maxim_TS
Postby Maxim_TS » 15.01.16, 10:39
oldman, The USB utility is written as WDC Marvell USB/COM Image
Postby DataMedics » 19.01.16, 23:53
petkus wrote:Source of the post Hi,
Regards,
Peter
All you have to do is jam the Samsung adapter in there and bam! it works.
Filipp_TS
Postby Filipp_TS » 03.02.16, 15:52
Dear Oldman,
This option available in utility. Select Western Digital -> WDC Marvell USB/COM option.
drdoc
Postby drdoc » 13.02.17, 10:45
how to make com port connection to
800041 board
800022 board
skype: wayne_horner
Alandata Data Recovery
300ddr
Postby 300ddr » 15.02.17, 02:40
Thanks Wayne, this will be very useful!
lcoughey
Postby lcoughey » 15.02.17, 14:35
Thanks Wayne, I've been meaning to take a few minutes to figure it out myself.
Postby Amarbir[CDR-Labs] » 17.02.17, 18:55
drdoc wrote:Source of the post how to make com port connection to
800041 board
800022 board
Wayne ,
No ground necessary ?
Postby DataMedics » 20.02.17, 22:07
I think a ground connection is pretty much always optional with WD. I never bother.
Postby Amarbir[CDR-Labs] » 21.02.17, 06:26
DataMedics wrote:Source of the post I think a ground connection is pretty much always optional with WD. I never bother.
Jared ,
I think its working cos usb ground might be in use :D
Postby DataMedics » 22.02.17, 20:23
Exactly. And even with the SATA boards, I never bother with a ground and it works too. Probably because it's getting the ground from the SATA power cable.
Return to “WD USB”
