Seagate ST3250310NS Fw.HPG2 F3 family Lock Led problem
Re: Seagate ST3250310NS Fw.HPG2 F3 family Lock Led problem
Postby Amarbir[CDR-Labs] » 11.12.16, 05:49
arun_gjl wrote:Source of the post what is lock led problem and what does it mean and effect if its happens.
Hello Arun ,
This problem means that the drive does not go into Terminal mode f3 and the drive remains busy/locked and terminal keeps displaying errors
arun_gjl
Postby arun_gjl » 13.12.16, 06:13
Amarbir ji
greetings
thanks for your swift response, I am new to this and seeking your help....
Arun Pr Sharma
Data Miner
Shree Hari Tech Solutions PVT Ltd
302, Bajaj House, 97 Nehru Place
New Delhi 110019
9871500200
dsolutions
Postby dsolutions » 12.01.17, 22:12
I am having the same issue, except the terminal does not display a F3> prompt at all. The terminal only shows a "Boot 0x20M Spin Up", and then a LED0000EE Error. The diag readouts are:
HDD family detecting...
Tech Key...
Error starting command "En Tech" (ABR)
Family ID: 00
Selected family......................... : 3F, Pharaoh
Model by ID............................. : ST_M13FQBL
Loading default settings!
Then press OK!
Tech Key...
Terminal : error detecting HDD terminal baud rate
Requesting FW Pkg ver ........ Z ÿ?7È
Detecting Phys Sct Size...
Error obtaining Phys Sect Size!
Detecting Max Head number...
Phys. heads............................. : Error
I have tried both methods for the LED error solution, and have tried the cntrl+z over a few dozen times. I have tried using a different rom with no effect. I have tried using a identical PCB with no effect. I am simply at a loss. Any help is greatly appreciated. Thanks!
dsolutions
Postby dsolutions » 13.01.17, 01:37
And also the model, Serial, and firmware are incorrect.
Model: ST31000524AS
P/N: 5VPC6XAR
Firmware: HP64 (Shows As 08030954 on Drive Info Section of UDMA)
