Intel H10 512GB SSD + 32GB Optane NVMe troubles - Is there a trick?
osity
Re: Intel H10 512GB SSD + 32GB Optane NVMe troubles - Is there a trick?
Postby osity » 27.01.23, 22:53
Which specific SSD Intel utility will be working with these optane drives and when can we expect to see it in a software update?
Postby Roman_TS » 28.01.23, 11:53
It's not going to be a new Intel Utility. We will provide only logic access without technologic mode.
Adapter will be announced later.
ioLogik
Postby ioLogik » 22.09.23, 01:00
Is there an ETA for that adapter Roman?
Postby Roman_TS » 22.09.23, 12:53
ioLogik wrote:Source of the post Is there an ETA for that adapter Roman?
Almost ready, but you've better to ask sales when it will be available in stock :)
osity
Postby osity » 25.02.24, 05:43
I was able to resolve this case.
Very tedious and time consuming to figure out what works but I think I may have come up with a method.
Looking forward to my next ones.
ThomasH
Postby ThomasH » 25.04.24, 18:34
I was curious about this adapter release too, and whether it would be compatible with the 4-port PC3000 Express or only with the PC3000 Portable?
Postby Roman_TS » 25.04.24, 20:07
Intel Optain drives are using PCIe bus, so only Portable III will get a full support of it. Express and UDMA can't work with PCIe based devices.
ThomasH
Postby ThomasH » 18.07.24, 19:32
Update: if you can read and save both the Optane and NAND partition to image files, UFS Explorer does work now. They have a good writeup on it. https://www.ufsexplorer.com/articles/ho ... el-optane/
Note: Follow their instructions and when pointing to the NAND part, use the entire NAND, and not just the main partition on the NAND.
Another Note: The Optane portion's clone must show as the same size as the original drive, so if not using an image file, make sure the HPA is set on the clone-drive to the same amount of sectors as the original optane drive had. Otherwise, the Intel Cache section doesn't show up to start with.
Return to “Other NVMe drives”
