hts725016a9a364 swapped heads, now no spin
drdoc
Postby drdoc » 08.03.12, 22:13
its 1 platter 2 heads. so head map is same. we didnt swap pcb. parts came from same model.
its a 2.5 inch hts725016a9a364. mlc da3332 same model same date same boards 2 lines same.
just dwapped heads.
have hitachi
would come ready after a long time and partially read
backedup hd resources.
swapped heads
now it wont spin up
tried donor board and it wont spin either.
read somewhere that swapping a board on these can set flags in nvram and make donor no good - but it can be fixed.
what should be done next?
========== sa structure test
Selected family......................... : CUSTOM
Model by ID............................. : Hitachi HTS725016A9A364
ROM ID.................................. : M0M3
NV-RAM ID............................... : C72E
RESF version............................ : C72E
NV-RAM parameters
NV-RAM report
Checksum................................ : Ok
mu-code................................. : C72E
FW Ver Code............................. : 0x00010002
Head map................................ : 0 1 FF FF
FW boot flag............................ : 0x01
SA top cyl delimiters (by heads)........ : 0x801013; 0x366680; 0xB3666; 0x16901
Used module table
Report on module RESF, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
FW Ver code............................. : 00000000
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : :(original): (sect): (sect): (byte) : RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 3 : 3 : 1536 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 3 : 0 : 1536 : 00000000 : No : : SA marker
RSVD : F : B : 7FD00003 : 7FD20000 : 3 : 0 : 1536 : 00000000 : No : : SA marker
RESF : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : 1 : B : 7FE21000 : 7FE20000 : 2 : 0 : 0 : 000FFFFF : No : : Main module table
RESF : F : B : 7FE00003 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 165 : 165 : 0 : 00058400 : Yes : Ok : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 165 : 0 : 0 : 00058400 : No : : Code module
RAM0 : F : B : 7FE00005 : 7FE20002 : 165 : 165 : 0 : 00058400 : Yes : Ok : Code module
OVR0 : 0 : B : 7FE200A7 : 7FE200A7 : 18 : 18 : 0 : 0006CE00 : Yes : Ok : Code overlay module
OVR0 : 1 : B : 7FE210A7 : 7FE200A7 : 18 : 0 : 0 : 0006CE00 : No : : Code overlay module
OVR0 : F : B : 7FE000AA : 7FE200A7 : 18 : 18 : 0 : 0006CE00 : Yes : Ok : Code overlay module
RESF : 0 : B : 7FE200B9 : 7FE200B9 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : 1 : B : 7FE210B9 : 7FE200B9 : 2 : 0 : 0 : 000FFFFF : No : : Main module table
RESF : F : B : 7FE000BC : 7FE200B9 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PTCH : 0 : B : 7FE200BB : 7FE200BB : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE210BB : 7FE200BB : 2 : 0 : 0 : 000FFFFF : No : : Microcode connections table module
PTCH : F : B : 7FE000BE : 7FE200BB : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
CNS1 : 0 : B : 7FE200BD : 7FE200BD : 1 : 1 : 460 : 00035C7A : Yes : Ok : HDD logical configuration module
CNS1 : 1 : B : 7FE210BD : 7FE200BD : 1 : 0 : 460 : 00035C7A : No : : HDD logical configuration module
CNS1 : F : B : 7FE000C0 : 7FE200BD : 1 : 1 : 460 : 00035C7A : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200BE : 7FE200BE : 1 : 1 : 254 : 00035E7A : Yes : Ok :
RWCN : 1 : B : 7FE210BE : 7FE200BE : 1 : 0 : 254 : 00035E7A : No : :
RWCN : F : B : 7FE000C1 : 7FE200BE : 1 : 1 : 254 : 00035E7A : Yes : Ok :
ZONE : 0 : Ad : 7FE200BF : 7FE200BF : 17 : 17 : 8182 : 00033A00 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE210BF : 7FE200BF : 17 : 0 : 8182 : 00033A00 : No : : Zone allocation table module
ZONE : F : Ad : 7FE000C2 : 7FE200BF : 17 : 17 : 8182 : 00033A00 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE200D0 : 7FE200D0 : 2 : 2 : 1568 : 000043E0 : Yes : Ok :
PTRT : 1 : B : 7FE210D0 : 7FE200D0 : 2 : 0 : 1568 : 000043E0 : No : :
PTRT : F : B : 7FE000D3 : 7FE200D0 : 2 : 2 : 1568 : 000043E0 : Yes : Ok :
SMRT : 0 : B : 7FE200D2 : 7FE200D2 : 1 : 1 : 0 : 000FFFFF : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210D2 : 7FE200D2 : 1 : 0 : 0 : 000FFFFF : No : : S.M.A.R.T. module
SMRT : F : B : 7FE000D5 : 7FE200D2 : 1 : 1 : 0 : 000FFFFF : Yes : Ok : S.M.A.R.T. module
SRVP : 0 : B : 7FE200D3 : 7FE200D3 : 3 : 3 : 1170 : 000364BC : Yes : Ok :
SRVP : 1 : B : 7FE210D3 : 7FE200D3 : 3 : 0 : 1170 : 000364BC : No : :
SRVP : F : B : 7FE000D6 : 7FE200D3 : 3 : 3 : 1170 : 000364BC : Yes : Ok :
SRVM : 0 : Ad : 7FE200D6 : 7FE200D6 : 8 : 8 : 4096 : 00032A00 : Yes : Ok : Module contains cylinder defects table
SRVM : 1 : Ad : 7FE210D6 : 7FE200D6 : 8 : 0 : 4096 : 00032A00 : No : : Module contains cylinder defects table
SRVM : F : Ad : 7FE000D9 : 7FE200D6 : 8 : 8 : 4096 : 00032A00 : Yes : Ok : Module contains cylinder defects table
CHNL : 0 : Ad : 7FE200DE : 7FE200DE : 21 : 21 : 10752 : 00030000 : Yes : Ok :
CHNL : 1 : Ad : 7FE210DE : 7FE200DE : 21 : 0 : 10752 : 00030000 : No : :
CHNL : F : Ad : 7FE000E1 : 7FE200DE : 21 : 21 : 10752 : 00030000 : Yes : Ok :
IDNT : 0 : B : 7FE200F3 : 7FE200F3 : 2 : 2 : 184 : 0002F7D8 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210F3 : 7FE200F3 : 2 : 0 : 184 : 0002F7D8 : No : : HDD ID data module
IDNT : F : B : 7FE000F6 : 7FE200F3 : 2 : 2 : 184 : 0002F7D8 : Yes : Ok : HDD ID data module
SN00 : 0 : B : 7FE200F4 : 7FE200F4 : 1 : 1 : 20 : 0002F7EC : Yes : Ok : Module contains HDD SN
SN00 : 1 : B : 7FE210F4 : 7FE200F4 : 1 : 0 : 20 : 0002F7EC : No : : Module contains HDD SN
SN00 : F : B : 7FE000F7 : 7FE200F4 : 1 : 1 : 20 : 0002F7EC : Yes : Ok : Module contains HDD SN
MISC : 0 : B : 7FE200F5 : 7FE200F5 : 1 : 1 : 28 : 00035C56 : Yes : Ok :
MISC : 1 : B : 7FE210F5 : 7FE200F5 : 1 : 0 : 28 : 00035C56 : No : :
MISC : F : B : 7FE000F8 : 7FE200F5 : 1 : 1 : 28 : 00035C56 : Yes : Ok :
ICES : 0 : B : 7FE200F6 : 7FE200F6 : 1 : 1 : 74 : 0002F8A6 : Yes : Ok : Security information module
ICES : 1 : B : 7FE210F6 : 7FE200F6 : 1 : 0 : 74 : 0002F8A6 : No : : Security information module
ICES : F : B : 7FE000F9 : 7FE200F6 : 1 : 1 : 74 : 0002F8A6 : Yes : Ok : Security information module
MLBA : 0 : B : 7FE200F7 : 7FE200F7 : 1 : 1 : 10 : 00035C46 : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE210F7 : 7FE200F7 : 1 : 0 : 10 : 00035C46 : No : : HDD logical configuration module
MLBA : F : B : 7FE000FA : 7FE200F7 : 1 : 1 : 10 : 00035C46 : Yes : Ok : HDD logical configuration module
QMCN : 0 : B : 7FE200F8 : 7FE200F8 : 4 : 4 : 2048 : 00038A00 : Yes : Ok :
QMCN : 1 : B : 7FE210F8 : 7FE200F8 : 4 : 0 : 2048 : 00038A00 : No : :
QMCN : F : B : 7FE000FB : 7FE200F8 : 4 : 4 : 2048 : 00038A00 : Yes : Ok :
SMRT : 0 : B : 7FE200FC : 7FE200FC : 1 : 1 : 473 : 00035F7A : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210FC : 7FE200FC : 1 : 0 : 473 : 00035F7A : No : : S.M.A.R.T. module
SMRT : F : B : 7FE000FF : 7FE200FC : 1 : 1 : 473 : 00035F7A : Yes : Ok : S.M.A.R.T. module
PNID : 0 : D : 7FE200FD : 7FE200FD : 2 : 2 : 0 : 00FFFFFF : Yes : Ok : Module contains information from label on PCB
PNID : 1 : D : 7FE210FD : 7FE200FD : 2 : 0 : 0 : 00FFFFFF : No : : Module contains information from label on PCB
PNID : F : D : 7FE00100 : 7FE200FD : 2 : 2 : 0 : 00FFFFFF : Yes : Error : Module contains information from label on PCB
SMRA : 0 : : 7FE200FF : 7FE200FF : 1 : 1 : 354 : 00037F84 : Yes : Ok :
SMRA : 1 : : 7FE210FF : 7FE200FF : 1 : 0 : 354 : 00037F84 : No : :
SMRA : F : : 7FE00102 : 7FE200FF : 1 : 1 : 354 : 00037F84 : Yes : Ok :
ABLP : 0 : B : 7FE20100 : 7FE20100 : 1 : 1 : 104 : 00036E32 : Yes : Ok :
ABLP : 1 : B : 7FE21100 : 7FE20100 : 1 : 0 : 104 : 00036E32 : No : :
ABLP : F : B : 7FE00103 : 7FE20100 : 1 : 1 : 104 : 00036E32 : Yes : Ok :
ABLD : 0 : B : 7FE20101 : 7FE20101 : 1 : 1 : 144 : 00036DA2 : Yes : Ok :
ABLD : 1 : B : 7FE21101 : 7FE20101 : 1 : 0 : 144 : 00036DA2 : No : :
ABLD : F : B : 7FE00104 : 7FE20101 : 1 : 1 : 144 : 00036DA2 : Yes : Ok :
SSTL : 0 : B : 7FE20102 : 7FE20102 : 2 : 2 : 0 : 000FFFFF : Yes : Skip :
SSTL : 1 : B : 7FE21102 : 7FE20102 : 2 : 0 : 0 : 000FFFFF : No : :
SSTL : F : B : 7FE00105 : 7FE20102 : 2 : 2 : 0 : 000FFFFF : Yes : Skip :
SERL : 0 : B : 7FE20104 : 7FE20104 : 2 : 2 : 1024 : 0002FC00 : Yes : Skip : S.M.A.R.T. error log module
SERL : 1 : B : 7FE21104 : 7FE20104 : 2 : 0 : 1024 : 0002FC00 : No : : S.M.A.R.T. error log module
SERL : F : B : 7FE00107 : 7FE20104 : 2 : 2 : 1024 : 0002FC00 : Yes : Skip : S.M.A.R.T. error log module
SSST : 0 : B : 7FE20106 : 7FE20106 : 1 : 1 : 512 : 00007000 : Yes : Skip :
SSST : 1 : B : 7FE21106 : 7FE20106 : 1 : 0 : 512 : 00007000 : No : :
SSST : F : B : 7FE00109 : 7FE20106 : 1 : 1 : 512 : 00007000 : Yes : Skip :
SKPO : 0 : : 7FE20107 : 7FE20107 : 1 : 1 : 144 : 0002F680 : Yes : Error :
SKPO : 1 : : 7FE21107 : 7FE20107 : 1 : 0 : 144 : 0002F680 : No : :
SKPO : F : : 7FE0010A : 7FE20107 : 1 : 1 : 144 : 0002F680 : Yes : Error :
DCOT : 0 : B : 7FE20108 : 7FE20108 : 1 : 1 : 22 : 00035C30 : Yes : Ok :
DCOT : 1 : B : 7FE21108 : 7FE20108 : 1 : 0 : 22 : 00035C30 : No : :
DCOT : F : B : 7FE0010B : 7FE20108 : 1 : 1 : 22 : 00035C30 : Yes : Ok :
SRIF : 0 : B : 7FE20109 : 7FE20109 : 1 : 1 : 4 : 00036D9E : Yes : Ok : Self Test start management module
SRIF : 1 : B : 7FE21109 : 7FE20109 : 1 : 0 : 4 : 00036D9E : No : : Self Test start management module
SRIF : F : B : 7FE0010C : 7FE20109 : 1 : 1 : 4 : 00036D9E : Yes : Ok : Self Test start management module
BULK : 0 : : 7FE2010A : 7FE2010A : 1 : 1 : 176 : 0002F710 : Yes : Ok :
BULK : 1 : : 7FE2110A : 7FE2010A : 1 : 0 : 176 : 0002F710 : No : :
BULK : F : : 7FE0010D : 7FE2010A : 1 : 1 : 176 : 0002F710 : Yes : Ok :
ALTT : 0 : : 7FE2010B : 7FE2010B : 1 : 1 : 512 : 00005E00 : Yes : Ok :
ALTT : 1 : : 7FE2110B : 7FE2010B : 1 : 0 : 512 : 00005E00 : No : :
ALTT : F : : 7FE0010E : 7FE2010B : 1 : 1 : 512 : 00005E00 : Yes : Ok :
DBGC : 0 : : 7FE2010C : 7FE2010C : 1 : 1 : 78 : 00039E70 : Yes : Ok :
DBGC : 1 : : 7FE2110C : 7FE2010C : 1 : 0 : 78 : 00039E70 : No : :
DBGC : F : : 7FE0010F : 7FE2010C : 1 : 1 : 78 : 00039E70 : Yes : Ok :
OFDT : 0 : : 7FE2010D : 7FE2010D : 1 : 1 : 0 : 000FFFFF : Yes : Ok :
OFDT : 1 : : 7FE2110D : 7FE2010D : 1 : 0 : 0 : 000FFFFF : No : :
OFDT : F : : 7FE00110 : 7FE2010D : 1 : 1 : 0 : 000FFFFF : Yes : Ok :
RDMT : 0 : Ad : 7FE40000 : 7FE40000 : 80 : 80 : 0 : 000A3C00 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE41000 : 7FE40000 : 80 : 0 : 0 : 000A3C00 : No : : G-List module
RDMT : F : Ad : 7FE01000 : 7FE40000 : 80 : 0 : 0 : 000A3C00 : No : : G-List module
RELI : 0 : B : 7FE40050 : 7FE40050 : 1 : 1 : 0 : 000ADC00 : Yes : Skip :
RELI : 1 : B : 7FE41050 : 7FE40050 : 1 : 0 : 0 : 000ADC00 : No : :
RELI : F : B : 7FE01050 : 7FE40050 : 1 : 0 : 0 : 000ADC00 : No : :
PSHT : 0 : Ad : 7FE40051 : 7FE40051 : 630 : 630 : 0 : 000ADE00 : Yes : Ok : P-List module
PSHT : 1 : Ad : 7FE41051 : 7FE40051 : 630 : 0 : 0 : 000ADE00 : No : : P-List module
PSHT : F : Ad : 7FE01051 : 7FE40051 : 630 : 0 : 0 : 000ADE00 : No : : P-List module
OVR1 : 0 : B : 7FE50000 : 7FE50000 : 72 : 72 : 0 : 000FFFFF : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE51000 : 7FE50000 : 72 : 0 : 0 : 000FFFFF : No : : Code overlay module
SPRE : 0 : B : 7FE50048 : 7FE50048 : 54 : 54 : 0 : 000FFFFF : Yes : Skip :
SPRE : 1 : B : 7FE51048 : 7FE50048 : 54 : 0 : 0 : 000FFFFF : No : :
PESD : : D : 7FE60000 : 7FE60000 : 128 : 128 : 0 : 000FFFFF : Yes : Ok : PES data log
MFGP : : Dr : 7FE61000 : 7FE61000 : 1 : 0 : 0 : 000FFFFF : No : : Self Test parameters module
SRST : : C : 7FE70000 : 7FE70000 : 128 : 128 : 0 : 000FFFFF : Yes : Skip : Self Test report module
FLOG : : B : 7FE80000 : 7FE80000 : 128 : 128 : 0 : 000FFFFF : Yes : Skip :
DUMP : : D : 7FE90000 : 7FE90000 : 378 : 1 : 0 : 000FFFFF : No : : Self Test log
CHNM : : Ad : 7FE200DE : 7FE200DE : 21 : 21 : 0 : 00000000 : Yes : Ok :
RDM1 : : Ad : 7FE40000 : 7FE40000 : 80 : 80 : 0 : 00000000 : Yes : Ok : G-List module (RDM1 - reference to RDMT)
RDM2 : : Ad : 7FE41000 : 7FE41000 : 80 : 0 : 0 : 00000000 : No : : G-List module (copy)
ELG1 : : C : 7FEF0000 : 7FEF0000 : 711 : 711 : 0 : 00000000 : Yes : Skip : Log module
ELG2 : : C : 7FEF1000 : 7FEF1000 : 711 : 0 : 0 : 00000000 : No : : Log module
EVLG : : C : 7FEE0000 : 7FEE0000 : 256 : 256 : 0 : 00000000 : Yes : Ok : Log module (event log)
PID1 : : D : 7FE200FD : 7FE200FD : 2 : 2 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PID2 : : D : 7FE210FD : 7FE210FD : 2 : 0 : 0 : 00000000 : No : : Module contains information from label on PCB
PIDM : : D : 7FE00000 : 7FE00000 : 3 : 3 : 0 : 00000000 : Yes : Ok : Module contains information from label on PCB
PDM1 : : Ad : 7FE40051 : 7FE40051 : 630 : 630 : 0 : 00000000 : Yes : Ok : P-List module (PDM1 - reference to PSHT)
PDM2 : : Ad : 7FE41051 : 7FE41051 : 630 : 0 : 0 : 00000000 : No : : P-List module (copy)
AMPM : : B : 7FE61083 : 7FE61083 : 1 : 0 : 0 : 00000000 : No : : Factory tests log module (AMPM)
HLR1 : : B : 7FE50080 : 7FE50080 : 5 : 5 : 0 : 00000000 : Yes : Ok : Factory tests log module (HLRC)
HLR2 : : B : 7FE51080 : 7FE51080 : 5 : 0 : 0 : 00000000 : No : : Factory tests log module (HLRC, copy)
MFGT : : : 7FED0000 : 7FED0000 : 1 : 1 : 0 : 00000000 : Yes : Error :
DDD0 : : B : 7FE61080 : 7FE61080 : 2 : 0 : 0 : 00000000 : No : : DDD utility log module
MRDM : : B : 7FE61082 : 7FE61082 : 1 : 0 : 0 : 00000000 : No : :
DIAG : : B : 7FE61088 : 7FE61088 : 575 : 0 : 0 : 00000000 : No : : Native diagnostic utilities log module
WRT0 : : B : 7FEA0000 : 7FEA0000 : 711 : 637 : 0 : 00000000 : No : : Marker at head 0
WRT1 : : B : 7FEA1000 : 7FEA1000 : 711 : 0 : 0 : 00000000 : No : : Marker at head 1
@@01 : : : 7FE61001 : 7FE61001 : 127 : 0 : 65024 : 12E7FF50 : No : : Additional SA track hole
@@02 : : : 7FE61084 : 7FE61084 : 4 : 0 : 2048 : 12E7FF50 : No : : Additional SA track hole
Modules checking completed
Information about copy 0
Report on module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 3
Report on module RAM0, "Code module"
ABA..................................... : 7FE20002
Length (sectors)........................ : 165
FW Ver code............................. : 20039EFA
Report on module OVR0, "Code overlay module"
ABA..................................... : 7FE200A7
Length (sectors)........................ : 18
Report on module OVR1, "Code overlay module"
ABA..................................... : 7FE50000
Length (sectors)........................ : 72
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200F3
Firmware................................ : PCBO
Model................................... : Hitachi HTS725016A9A304
Serial.................................. : PCKB00VNG5V9ZJ
Report on module CNS1, "HDD logical configuration module"
ABA..................................... : 7FE200BD
AutoReassign............................ : ON
Maximal LBA............................. : 312581807
Report on module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE200F7
Capacity................................ : 0
Report on module ZONE, "Zone allocation table module"
ABA..................................... : 7FE200BF
Length (sectors)........................ : 17
Head count.............................. : 2
Full capacity........................... : 314858760
ABA sub-zones count..................... : 1762
ABA sub-zones cyl. step by heads........ : 2E 64
# Init. Cyl End Cyl Head SPT
0 : 0 : 3299 : 0 : 1560
: 0 : 7271 : 1 : 1620
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
1 : 3300 : 9524 : 0 : 1530
: 7272 : 11447 : 1 : 1584
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
2 : 9525 : 17099 : 0 : 1476
: 11448 : 15551 : 1 : 1560
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
3 : 17100 : 27524 : 0 : 1440
: 15552 : 21383 : 1 : 1530
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
4 : 27525 : 32249 : 0 : 1404
: 21384 : 28079 : 1 : 1476
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
5 : 32250 : 36899 : 0 : 1380
: 28080 : 37151 : 1 : 1440
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
6 : 36900 : 43424 : 0 : 1350
: 37152 : 40463 : 1 : 1404
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
7 : 43425 : 47999 : 0 : 1320
: 40464 : 45359 : 1 : 1380
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
8 : 48000 : 50699 : 0 : 1296
: 45360 : 50975 : 1 : 1350
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
9 : 50700 : 60599 : 0 : 1260
: 50976 : 55007 : 1 : 1320
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
10 : 60600 : 65024 : 0 : 1224
: 55008 : 57383 : 1 : 1296
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
11 : 65025 : 69749 : 0 : 1200
: 57384 : 66959 : 1 : 1224
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
12 : 69750 : 74999 : 0 : 1170
: 66960 : 69479 : 1 : 1224
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
13 : 75000 : 79199 : 0 : 1140
: 69480 : 74303 : 1 : 1200
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
14 : 79200 : 82949 : 0 : 1110
: 74304 : 79919 : 1 : 1170
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
15 : 82950 : 91124 : 0 : 1080
: 79920 : 86903 : 1 : 1110
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
16 : 91125 : 94799 : 0 : 1044
: 86904 : 95039 : 1 : 1080
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
17 : 94800 : 98849 : 0 : 1020
: 95040 : 98063 : 1 : 1044
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
18 : 98850 : 104399 : 0 : 990
: 98064 : 102167 : 1 : 1020
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
19 : 104400 : 111449 : 0 : 930
: 102168 : 107279 : 1 : 990
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
20 : 111450 : 119624 : 0 : 900
: 107280 : 110879 : 1 : 960
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
21 : 119625 : 122774 : 0 : 864
: 110880 : 113687 : 1 : 930
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
22 : 122775 : 126749 : 0 : 840
: 113688 : 120887 : 1 : 900
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
23 : 126750 : 132149 : 0 : 780
: 120888 : 126863 : 1 : 840
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
Report on module RDMT, "G-List module"
ABA..................................... : 7FE40000
Length (sectors)........................ : 80
Header
Capacity................................ : 4933
Defects count........................... : 1
In spare area........................... : 0
Described sectors in User Area.......... : 4
Totally remaped......................... : 4
SMART, Realloc Event Count.............. : 1
SMART, Pending Count.................... : 0
Data:
Candidate............................... : 0
Total hidden (cand.).................... : 0
Total hidden (grown).................... : 1
Information about copy 1
Module not loaded! ID = RSVD Copy 1; SA marker
Error : Module is not loaded (RSVD, SA marker)
Module not loaded! ID = RESF Copy 1; Main module table
Error : Module is not loaded (RESF, Main module table)
Module not loaded! ID = RAM0 Copy 1; Code module
Error : Module is not loaded (RAM0, Code module)
Module not loaded! ID = OVR0 Copy 1; Code overlay module
Error : Module is not loaded (OVR0, Code overlay module)
Module not loaded! ID = OVR1 Copy 1; Code overlay module
Error : Module is not loaded (OVR1, Code overlay module)
Module not loaded! ID = IDNT Copy 1; HDD ID data module
Error : Module is not loaded (IDNT, HDD ID data module)
Module not loaded! ID = CNS1 Copy 1; HDD logical configuration module
Error : Module is not loaded (CNS1, HDD logical configuration module)
Module not loaded! ID = MLBA Copy 1; HDD logical configuration module
Error : Module is not loaded (MLBA, HDD logical configuration module)
Module not loaded! ID = ZONE Copy 1; Zone allocation table module
Error : Module is not loaded (ZONE, Zone allocation table module)
Module not loaded! ID = RDMT Copy 1; G-List module
Error : Module is not loaded (RDMT, G-List module)
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
mu-code................................. : D7E4
Incompatible with NV-RAM!
FW Ver code............................. : C8BD3A18
Incompatible with active RESF!
Firmware................................ : PCBQ
Model................................... : Hitachi HTS725016A9SA00
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
: 0 : 0 : 2 : 0
: 0 : 0 : 3 : 0
Module not loaded! ID = RDMT Copy F; G-List module
Information about common modules (Open+Spec)
Report on module PIDM, "Module contains information from label on PCB"
ABA..................................... : 7FE00000
PN...................................... : 0A78271
PCB ID.................................. : 0A71428DA3005_Pzg0053BZZ
Module not loaded! ID = MFGP; Self Test parameters module
Error : Module is not loaded (MFGP, Self Test parameters module)
skype: wayne_horner
Alandata Data Recovery
Re: hts725016a9a364 swapped heads, now no spin
Postby ACE_Admin » 16.03.12, 10:22
Tell me, what happens after you power on the drive? Arent there any strange noises from drive?
Also, have you tried to measure the resistance on spinldle motor contacts? It is a good idea to check and find if there is a difference
with a good working drive.
Also check, if you have transfered donor heads together with their magnets to patient. Maybe original drive's magnets are not compartible.
Another thing to check is donor hears. If they work fine in the drive they worked before, but aren't working in patient drive, most likely
they are incompartible.
But if donor heads are unable to work in a drive they were taken from, then most likely patient drive has a scratched surface.
In this case each new head will come damaged very quickly after you will use it with patient drive.
drdoc
Postby drdoc » 16.03.12, 23:36
thanks for the reply
I think the issue was bad donor heads.
although I did try to isolate the heads to see what effect that would have.
Isolating the heads made the good drive not spin-up - fyi
skype: wayne_horner
