HAI ALL,
i have one Seagate HDD Model:ST500DM002 , FW:KC45. It showing Capaity ,model,serial everything showing properly. When i enter into the Utility (Ctrl+Z) it showing the following Messages.
F3 T>
Boot 0x10M
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
InitiateMarkPendingReallocateRequest for disc_lba: 00136BD4!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BD5!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BD6!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BD7!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BD8!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BD9!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BDA!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BDB!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BDC!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BDD!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BDE!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BDF!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BE0!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BE1!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BE2!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BE3!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BE4!
InitiateMarkPendingReallocateRequest for disc_lba: 00136BE5!
ASCII Diag mode
What type of error is showing ? and how I can solve it?
HELP me
ST500DM002-KC45
- GuideRecovery
Re: ST500DM002-KC45
CONGEN
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
Re: ST500DM002-KC45
THANKU
Please explain more
How it works and where I should use this command . ie F3 T > ,after/before etc
betty
crystal
Please explain more
betty
crystal
Re: ST500DM002-KC45
Hai all,
I have tried Recover Translator. then i was getting this terminal output
Test : Recover translator
Start from LBA.................................... : 0
Translation "forks" list file..................... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\F3 Arch (common)\ST500DM002-1BD142-KC45-S2AA7WRQ\Defects\TranslationForks.lba
Maximal defect chain length....................... : 64
Take into account P-List.......................... : Yes
At ambiguity hide "left" UNC...................... : Yes
Process "32 byte tail" bug........................ : Yes
HDD ID reading...
Detecting defects hiding cmd type...
Error detecting defects hiding cmd type!
HDD ID reading...
Re: ST500DM002-KC45
hai to all
the terminal out put of same HDD is like this:
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Any one have any idea , please share with me
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Dither
Re: ST500DM002-KC45
Probably this drive will reach ready condition by itself after some time.
Problem is relocation process is with errors meaning the process of relocating bad blocks is causing issues, or alt list is full.
Translator recovery will not help.
Access settings udner 'HDD ID' and uncheck all boxes.
also, it is very dangerous to try different commands in the wrong circumstances, such as translator recovery when translator is fine as this will clear NRG and Glist and there is no certainty that it can restore successful with no manual intervention
