Silicon Power A55 really supported?
AdasRip
Postby AdasRip » 13.06.23, 17:23
I got the SP A55 drive with SATAS11 issue.
I choose Silicon Power A55 / Hosin Global Phison / Controler HG2258 (PS3111) / Silicon Power A55 family.
Utilities is reported as follows:
Selected family......................... : Silicon Power A55
Controller.............................. : HG2258 (PS3111)
SSD status:
Firmware mode........................... : ROM
Chips id................................ : 0x000000000000
Vendor.................................. : Unknown
Type.................................... : SLC
Then I try to load the loader (any of the 3 available) but I get an error:
Loader uploading
Code name............................... : Burner_HG2258_EB1.0.bin
Write seed.............................. : Ok
Write PRAM.............................. : Ok
Checking................................ : Ok
Write overlay into PRAM................. : Ok
Write HDD microcode .................... : Ok
SSD status:
Firmware mode........................... : LDR
Read System Info........................ : Ok
Invalid blocks per chip value (0x0000)
Parameter "BlocksPerChip"=0x0100
Invalid pages per block value (0x0000)
Parameter "PagesPerBlock"=0x0100
Read Chips Info......................... : Ok
Re: Silicon Power A55 really supported?
Postby Roman_TS » 14.06.23, 09:57
Silicon Power A55 can be based on a few different controllers. It could be SM2259XT, it could be SM2258XT, PS3108, PS3109, PS3110, PS3111, HS2258, AS2258.
The question is - what is your real CPU name if you open the drive cover?
At anyway - forum - is not a place where you can get a personal help. For remote support, better to make a new ticket.
AdasRip
Postby AdasRip » 14.06.23, 12:25
Real CPU name - Phison PS3111-S11 as shown at attachment.
Anticipating your answer, I will write that I have also tested all loaders for the regular Phison S11.
Postby Roman_TS » 14.06.23, 12:36
You can use any Utility for PS3111. In your first post, you mentioned Controller HG2258 - a bit different model (different FW in compare with PS3111).
So, use SmartBuy vendor and select PS3111. Then load the loaoder and move forward with other steps.
AdasRip
Postby AdasRip » 14.06.23, 12:49
Ok, I will check out SmartBuy although I've already tested all loaders for Phison S11 for the SP S55 and A56 family.
Thank you for your quick response and willingness to help.
d_d_recovery
Postby d_d_recovery » 14.06.23, 15:33
Are you using a PATA or SATA connection?
Postby Roman_TS » 15.06.23, 15:05
AdasRip wrote:Source of the post Ok, I will check out SmartBuy although I've already tested all loaders for Phison S11 for the SP S55 and A56 family.
Don't forget that:
1. If you are using PC-3000 Express or UDMA, you should plug PS3109 and PS3111 based drives via PATA to SATA adapter!
2. Drive must be switched into SAFE MODE and be in SAFE all the time - it's important;
3. Make sure that all NAND chips are passing the Memory Chip Test in Utility.
All PS3111 modifications are supported. Drive must return back data :)
AdasRip
Postby AdasRip » 23.06.23, 13:09
d_d_recovery wrote:Source of the post Are you using a PATA or SATA connection?
PATA via SATA-->PATA adapter.
AdasRip
Postby AdasRip » 23.06.23, 13:20
Roman_TS wrote:Don't forget that:
1 - Yes, I remember using the adapter. Anyway, Utilities remind about this.
2 - The drive automatically starts in Safe-Mode. Despite this I keep it shorted all the time.
3 - No NAND chip passes the test as the Utility states as below:
Memory chips test
Invalid channels count value (0x00)
Parameter "ChannelsCount"=0x01
Invalid page size value (0x0000)
Parameter "PageSize"=0x4000
Test completed
In reports:
BASIC INFORMATION
Type.................................... : SLC 16k
Chip capacity........................... : 1 024 Mb
Channels................................ : 1
Chips (Total)........................... : 0x10
LUNs per chip........................... : 1
Blocks per chip......................... : 0x100
Pages per block......................... : 0x100
Sectors per page........................ : 0x20
RAM size................................ : 1 Mb
Firmware version........................ : SBFM01.2
Build time.............................. : 11 Jun 2021
Interleaved blocks...................... : Type 0
Techno mode lock supported.............. : Yes
MEMORY MICROCHIP INFORMATION
: : Chip 0 :
: Channel 0 : :
Attention! The specified number of chips (16) does not correspond to the number of detected chips (0)!
Attention! The IDs of some chips are different!
Roman_TS wrote:All PS3111 modifications are supported. Drive must return back data :)
So mine is probably unlucky :(
Postby Roman_TS » 23.06.23, 18:29
Due to the log info, NAND chips are not reading. Probably something bad with CPU. Try to swap the NAND chips:
https://blog.acelab.eu.com/alternative- ... t-ssd.html
Return to “Other SSD”
