Is HTS541075A7E630 supported? Head map looks strange...
300ddr
Postby 300ddr » 03.02.17, 02:52
This drive is a bit noisy after powering on, but gets ready after a few seconds. There is no 5410A7 family, so using 5410A9, I enter utility. "No open modules." But refreshing ID shows full ID except size. When I tried to edit heads in nvram, things don't look normal:
Is it possible to edit this head map? Is this normal? Or does it looks like this because it's not supported yet?
Thanks,
Brian
lcoughey
Re: Is HTS541075A7E630 supported? Head map looks strange...
Postby lcoughey » 03.02.17, 16:08
I've found some newer Hitachi ARM drives giving some strange head maps, but not quite that weird. Either PC3K is looking at the wrong spot or those sectors are not being read correctly.
Sergey_TS
Postby Sergey_TS » 17.02.17, 08:58
300ddr, Yes, this is drive is not fully supported thus Head map looks strange via 'NV-RAM visual editing' (but it's not the sign of damage).
Correct Head map is located by 0x690 Offset for this model. So you can try to change it manually for checking damaged head.
sepid
Postby sepid » 17.04.18, 09:31
Sergey_TS wrote:300ddr, Yes, this is drive is not fully supported thus Head map looks strange via 'NV-RAM visual editing' (but it's not the sign of damage).
sorry
what is it 0x690 Offset?
and where is it 0x690 Offset?
please explain more
thanks
northwind
Postby northwind » 17.04.18, 10:10
I believe Sergey means that you need to open nv-ram, go to mentioned offset, change the HM and save nv-ram.
Sergey_TS
Postby Sergey_TS » 17.04.18, 12:40
sepid, you can find example in this topic :arrow: viewtopic.php?f=161&t=9614
