Advices for a not exact donor ST1500LM010
recovery
Postby recovery » 11.04.18, 17:06
We need a donor to do a head swap for a
SAMSUNG
ST1500LM010
HN-M151RAD/SBZ
We are not able to find any donor. We would like to know if we can try with a ST1500LM006 (we found many of them with the PN HN-M151RAD/*** (the last 3 letters differ).
Here some pictures:
Re: Advices for a not exact donor ST1500LM010
Postby DataMedics » 14.04.18, 04:15
You can read out the preamp type in terminal when the drives are powered on. That should give you a good idea if it'll be a compatible matched drive.
recovery
Postby recovery » 16.04.18, 10:57
The drive stays busy, here is the terminal output. What parameter is the most efficiency to check a compatible drive?
Code: Select all
ActiveFW : 00
FWVer : 0001SATA PLL done
DDR detected:32MB
*PA_TI5565*PA VID=0012 PN=0056 Rev=000A
*PA_TI5565*PA VID=0012 PN=0056 Rev=000AU
S_0
PCBA I/O Voltage : 2.5V
PREAMP : 2.5V
FLASH : 8Mbit
KONArev:6042
Vendor:ST
Maj.rev:4
Min.rev:2
Kona FSYS divider: 1
VN on
VN off
SO_1
Set Target RPM = 5409(0000906Fh)
IS Max= 200 (000Eh)
Set SDIS
SU Max= 450 (0020h)
RPLDone
RPA...........................Done
HODone @RPM= 865
RU.................................................................Done @RPM= 5400
ST.......Done @RPM= 5415
SUT= 2901
mS1 00000002
VDAC Offs K0 ............Done: 49
VN on
VBEMF Offs ....Done
VBEMF Gain ....Done
A1O=   19 A2O= -  8 SWO=    0
A1G= 1418 A2G=    7 SWG=   57
Rvcm=  11549 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load  = 3000 mips
LD............................................................................................................................................................................................................................................................................On Speed Fail
UD..OK : 57
VN off
PK_3   C:     0 H:0
Blizzard
Postby Blizzard » 16.04.18, 15:55
recovery wrote:Source of the post Hello,
recovery
Postby recovery » 16.04.18, 15:59
Thank you!
Blizzard
Postby Blizzard » 16.04.18, 16:11
recovery wrote:Source of the post Thank you!
Also, it is not guaranteed, but most of the time if you you match the H26A in the middle of the barcode P/N at bottom of label you have a good chance of preamp matching too.
recovery
Postby recovery » 16.04.18, 16:14
Thanks, I will try to find a donor.
Return to “Spin Point”
