I wondered if anyone could advise me on compatible donor parts as I have very few ST2000LM003 / 005 HDDs in stock for testing. I am looking for donor heads for a ST2000LM003, P/N: H2583-....
The only close HDD I had was that with P/N "G1" but the preamp is not a match. Other than trying to find another HDD with P/N which begins "H2" can any be helpful on if there are any other versions which are likely to provide a pre-amp match?
I know there is some tolerance in M8 series, for example use of heads from P/N "F1" work OK in "E7" HDDs.
Thanks,
J
ST2000LM003 Donor head requirements
Re: ST2000LM003 Donor head requirements
if you could post a picture of your patient and donors top label and their roms i can help you find donor for these ,
