Samsung Spin point ST1000LM024 NO MOVEMENT
CS DATA RECOVERY
Postby CS DATA RECOVERY » 02.08.16, 05:21
Dear
Seniors,
i have case Samsung spin point momentous ST1000LM024(2AR20003) drive was silent no movement only BSY i have tried replace same model donor PCB with replaced ROM then same no movement
after i have placed donor PCB with donor ROM spins good .
only original ROM not spins i have tried 2pcbs is it ROM damaged ?
Any solution...
Thanks & Regards
Pavan Kumar
CS DATA RECOVERY
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Garry_TS
Re: Samsung Spin point ST1000LM024 NO MOVEMENT
Postby Garry_TS » 02.09.16, 10:39
Hello Pavan,
What is a terminal log with original ROM?
dataq
Postby dataq » 22.11.17, 12:19
Did you manage to get a solution to this.
Return to “Spin Point”
