Would like to find the shorting points for ST2000LM007 (100835923).
This is how it looks as soon as the drive is connected on the terminal.
LED:0x000000BD FAddr:0x000074A2
After Tech Mode Unlocking, this is what terminal prints out:
Boot0x80M
TCC:001F
Tech Unlock Handshake: 0x3ECFFFC1
Reply:
Rst0x80M
T:0x0000 0x3FFFFFFF
TCC:001F:002A EMCDataErr:00000008
PrgF
(P)SATAReset
RAWOFF
PASS
Secondaryislatest!-00000001
Primaryisobsolete
[MCMTW_DSW]Primary-0002AD89
StartingLBAofRWRequest=00016038FBLength=00000861
ProcessRWError-Read-atLBA00016038FBSenseCode=43110081Out:
InitiateMarkPendingReallocateRequestfordisc_lba:00016038FBCHS:00007262.03.0000
ST2000LM007 - Shorting Point
Re: ST2000LM007 - Shorting Point
PreampType: 87 10 matchs with preamp 8210 ? i want to replace engine and heads because this problem, it readed a few part of disk and after appears this bug edac mcmt bla bla bla
F3 T>
Prod Desc: Janus.R1.SATA.Rosewood.Mule.Servo376.Rap30.4K + SMR Despo DFW BP6
Package Version: R1AEA069E.SDM4.650003.EB01
Serial #: ZDZA3TGX
Changelist: 01739083
Model #: ST2000LM007-1R8174
Servo FW Rev: 9E7E
Heads: 4
PCBA SN: C0325T1K
Default factory config: SD&D
Active config: SD&D
TotalHostWrites 00000000
NumberOfSegWrites 0000
TotalHPCBROs 00000000
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0001
MCSegmentUsed 0369
MCNodeUsed 0000023F
NullNodesUsed 00000000
Product FamilyId: AF, MemberId: 01
HDA SN: ZDZA3TGX, RPM: 5425, Wedges: 178, Heads: 4, OrigHeads: 4, ActiveHdMap: 000F, Lbas: 00001D593D47, PreampType: 82 10
Bits/Symbol: C, Symbols/UserSector: 0, Symbols/SystemSector: 0
PCBA SN: C0325T1K, Controller: JANUS_R1_SATA(2212), Channel: Unknown, PowerAsic: KONA Rev A042, BufferBytes: 8000000
SF ID: EF 14, SF Part Size: 400, Flash Used: 400
Package Version: R1AEA069E.SDM4.650003.EB01 , Package P/N: 100858084, Package Global ID: 00305567,
Package Build Date: 08/06/2019, Package Build Time: 01:04:42, Package CFW Version: R1AEA069E.SDM4.650003.01739083.00305567.EB01 ,
Package SFW1 Version: 9E7E, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 08060104, CustomerRel: EB01, Changelist: 01739083, ProdType: R1AEA06.SDM4, Date: 08/06/2019, Time: 010442, UserId: 00305567
Servo FW Rev: 9E7E
TCG IV Version: 30.05
Package BPN: 7
RAP FW Implementation Key: 1E, Format Rev: 0208, Contents Rev: 84 0B 01 00
Active BFW Container: 0
4K Sys Area: 1
Features:
- IOEDC enabled
- IOECC enabled
- DERP enabled v. 7.0.00.0000000000000000
- LTTC-UDR2 compiled off
- SuperParity 4.1 enabled OTF OC enabled
TotalSuperBlks TotalValidSuperBlks
001897AE 001897AE
- UMP Zone Group 0004 to 0005
TotalSuperBlks ValidSuperBlks
00004B1C 00004B1C
- Humidity Sensor disabled
- Media Cache Partition enabled
- Media Cache enabled
- Low Current Spin Up enabled
- Torn Write Protection enabled
- Zone Remap enabled-->RemapZoneTableTotalEntries: 00000004[PLBA:0000000000000000 Len:0000000001998FA8 Offset:000000001B73454C StartLLBA:000000001B73454C EndLLBA:000000001D0CD4F3][PLBA:0000000001998FA8 Len:000000001B73454C Offset:FFFFFFFFFE667058 StartLLBA:0000000000000000 EndLLBA:000000001B73454B][PLBA:000000001D0CD4F4 Len:00000000004C6853 Offset:0000000000000000 StartLLBA:000000001D0CD4F4 EndLLBA:000000001D593D46][PLBA:000000001D593D47 Len:0000000000000001 Offset:0000000000000000 StartLLBA:000000001D593D47
EndLLBA:000000001D593D47]
- AGB enabled
- SubRelease:0
- Critical Event Log v. 1
- DLS 2 enabled
- TA Reallocation disabled
- FAFH 70.0 disabled
- EWP:0
- DRAM Mirror:0
another hdd description
2 TB (3 907 029 168)
F3 T>
XI2
TCC:0016:0020 EMCDataErr:00000000
Serial #: ZDZJHZ07
Servo FW Rev: 9E7E
Heads: 4
PCBA SN: W148C5BN
Active config: SD&D
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0001
MCSegmentUsed 0000
MCNodeUsed 00000000
HDA SN: ZDZJHZ07, RPM: 5425, Wedges: 178, Heads: 4, OrigHeads: 4, ActiveHdMap: 000F, Lbas: 00001D593D47, PreampType: 87 10
PCBA SN: W148C5BN, Controller: JANUS_R1_SATA(2212), Channel: Unknown, PowerAsic: KONA Rev A042, BufferBytes: 8000000
Servo FW Rev: 9E7E
Package BPN: 7
4K Sys Area: 1
Features:
- IOEDC enabled
- IOECC enabled
0017DD26 0017DD26
00004696 00004696
- Zone Remap enabled-->RemapZoneTableTotalEntries: 00000004[PLBA:0000000000000000 Len:000000000198F9AD Offset:000000001B710DA0 StartLLBA:000000001B710DA0 EndLLBA:000000001D0A074C][PLBA:000000000198F9AD Len:000000001B710DA0 Offset:FFFFFFFFFE670653 StartLLBA:0000000000000000 EndLLBA:000000001B710D9F][PLBA:000000001D0A074D Len:00000000004F35FA Offset:0000000000000000 StartLLBA:000000001D0A074D EndLLBA:000000001D593D46][PLBA:000000001D593D47 Len:0000000000000001 Offset:0000000000000000 StartLLBA:000000001D593D47
- AGB enabled
- SubRelease:0
- DLS 2 enabled
- EWP:0
- DRAM Mirror:0
F3 T>
Serial #: ZDZA3TGX
Servo FW Rev: 9E7E
Heads: 4
PCBA SN: C0325T1K
Active config: SD&D
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0001
MCSegmentUsed 0369
MCNodeUsed 0000023F
Servo FW Rev: 9E7E
Package BPN: 7
4K Sys Area: 1
Features:
- IOEDC enabled
- IOECC enabled
001897AE 001897AE
00004B1C 00004B1C
- AGB enabled
- SubRelease:0
- DLS 2 enabled
- EWP:0
- DRAM Mirror:0
F3 T>
XI2
Serial #: ZDZJHZ07
Servo FW Rev: 9E7E
Heads: 4
PCBA SN: W148C5BN
Active config: SD&D
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0001
MCSegmentUsed 0000
MCNodeUsed 00000000
Servo FW Rev: 9E7E
Package BPN: 7
4K Sys Area: 1
Features:
- IOEDC enabled
- IOECC enabled
0017DD26 0017DD26
00004696 00004696
- AGB enabled
- SubRelease:0
- DLS 2 enabled
- EWP:0
- DRAM Mirror:0
Here you can find a shorting points for ST2000LM007:
https://blog.acelab.eu.com/pc-3000hdd-p ... rives.html
