Saving Files
Saving Files
I'm trying to saving the file of a recovery and it stops at 66% (only about half the files) and becomes grey as if it completed task. I'm renaming existing files and saving problem files to problem folder. Any insight would be appreciated. Please see attached image.
Re: Saving Files
Hello Joe,
Could you describe the procedure you save files? Do you save map of file or you save files from file directory?
Re: Saving Files
From the file directory, Right click on Root>Save>Save All Marked in Current Task. But I don't have this job anymore at this point.
